TR6 TR6 head torques?
kodanja
Can some one tell me the correct head bolt torque settings for a 71' tr6...?
thank you in advance /ubbthreads/images/graemlins/driving.gif
Label the studs on the manifold side front to rear K, G, C, A, E, I, M. Label the studs on the distributor side front to rear N, J, F, B, D, H, L. Thighten in two or three progressive stages in alphabetical order. This will help reduce the stress level on the head and block as you tighen them. /ubbthreads/images/graemlins/hammer.gif
I concur with Alec,
The 80lb might be a bit much. IMHO, torque to 65 and when you retorque, go to 75. Have you considered changing your head studs with new ones? Can't hurt.
Bill
As I said, according the BL TR6 Manual, the torque setting is 80 ft. lbs.
Do i hear a 70...who'll give me a 70? going once, going twice,BAMM 70 it is. Haynes circa 1969. Whats more fun than manuals with several different torque specs.
I'll bet the farm on my numbers because I know that FEMA will back me up. Er, they do still have FEMA, don't they?
Bill
Hello all,
I run a 10:1 compression engine at the figures I quoted, and with a spread as given I aim for about mid point.
Alec
I have been quite interested in this thread because my (cylinder) head is supposed to be finished tommorow.
My Bentley manual says 60 to 80. I am uncomfortable with such a range although I do know that an even torque is what matters most. I do like the 75 number a lot for two reasons. First it does fall in the range I mentioned and second if 80 is the top limit and my torque wrench is not properly callibrated I might easily exceed the limit. 75 gives me some piece of mind. At least a small piece. /ubbthreads/images/graemlins/crazyeyes.gif
