TR6 TR6 gas cap help
ichthos
I need some help with a gas cap. The magnet on my gas cap pulled away from the cap. Is this just glued in place? If so, what should I use to glue it back in place? Thanks, Kevin
TR3driver
Great Pumpkin - R.I.P
Wow, those magnetic caps are pretty rare. I heard the US authorities didn't like them, so the design was quickly changed to a mechanical latch. Too easy for the magnet to let go in a crash, or something.
I believe it was just glued in place. Not sure what the best glue would be to replace it, but JB Weld would probably do. Wipe the surfaces with acetone after cleaning away any dirt or traces of the old glue; then clamp it some way (maybe close the cap and put a weight on top ??) and let it sit overnight.
TRdoc
I have a TR250 and a TR6. Both have the magnets that you are describing. Mine once separated and I used epoxy glue to bind them back together.
TRdoc
I TR6 What glue for TR6 magnet in gas cap? Triumph 9
H TR6 TR6 Gas Cap Spring Tech Tip Triumph 4
Paulus TR6 Gas cap fitting on TR6 [71] Triumph 8
BierRunner TR6 TR6 Gas Pedal Triumph 4
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
B TR6 76 TR6 gas separation tank - orientation? Triumph 2
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
M TR6 TR6 Gas Leak From Front Carb Triumph 5
BobbyD TR6 TR6 Custom Aluminum Gas Tank ~ 15 Gallons Triumph 1
BobbyD TR6 TR4 & TR6 Gas Tanks Triumph 6
I TR6 75 TR6 rubber gas lines Triumph 6
I TR6 TR6 gas line leak - please help Triumph 15
T TR6 TR4a and TR6 gas tanks interchangeable? Triumph 10
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
hondo402000 TR6 Paint continues now the TR6 gas tank Triumph 9
B TR6 TR6 gas gauge stopped working Triumph 10
R TR6 TR6 Gas Tank Outlet Gas Tank to Body Seal Donut Triumph 6
TR6oldtimer TR6 Central Coast Calif gas and ping in a TR6 Triumph 2
mrv8q TR6 TR6 gas tank removal Triumph 13
I TR6 69 TR6 gas tank/emissions Triumph 10
B TR6 Draining gas tank and lines TR6 Triumph 3
I TR6 TR6 gas gauge not reading correctly Triumph 11
bobh TR6 TR6 Gas Pedal Shaft Bushing Install Triumph 16
teeslounge TR6 TR6 Sputter and Gas Triumph 8
S TR6 What were the manufacturer's estimates on gas mileage for a TR6 Triumph 4
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
