TR6 TR6 Fuel electric pump?
Gliderman8
Hello everyone- My complete resto is done except for tires. Since my '73 TR has only 30 miles on it since the total rebuild I am wondering about reliability issues. I have only had it on the road twice in the last week and unfortunately, old man winter is knocking at the door.
So, my question: When I get it out at the start of the season do you guys reccommend installing an electric fuel pump? I intend to drive this car; not as an everyday driver but I don't want to be afraid to take it where I want to go because of reliability issues.
Your thoughts please.
gliderman8
Brosky
I have spent a ton on my engine (and entire car) and I rebuilt my own mechanical fuel pump. If it was good enough for the past 34 years, it should take me another 34 as shown below.
https://www.74tr6.com/fuelpump.htm
Gliderman8
Gliderman8
Thanks Paul-
I also rebuilt my fuel pump with the rebuild kit. However, I did not go as far as getting everthing polished.
Yours looks fantastic!
Thanks for your thoughts.
DNK
If it's stock. The mechanical is just fine.
Gliderman8
Gliderman8
Thanks, that is good news about the mechanical fuel pump. Just looking to be ahead of the gremlins that creep up on road trips.
Trick6
I would never throw stones at any person's decision. If you want a mechanical pump, you should use one. I decided not to. Paul and I have the tri Stromberg carb set up but I use an electrical pump. I do carry a mechanical pump in my travel parts kit. This, the low pressure one, is the electric pump that I am using.
https://www.cbperformance.com/catalog.asp?ProductID=577
Brosky
I wasn't throwing stones Al, I just trust mechanicals slightly more than the electrical components on these cars!! The key word here is S-L-I-G-H-T-L-Y. :cheers:
Gliderman8
Gliderman8
Thanks for your input Al. For the moment, I will probably stick with the mechanical pump. I only have approx. 45 miles since the rebuild, so I will drive it for a while to shake things out that might need adjustment before installing an electric pump. I drove it briefly today, but I'm pretty sure it's back in the garage for the duration of the winter.
Elliot (gliderman8)
angelfj1
I second Paul's comment regarding electrical system reliability. If you intend to use your original alternator it is barely capable of handling the original stock electrical load. It's not a good ide to add anythig else! :nonono:
Gliderman8
Gliderman8
Wow... I had no idea that the stock alternator is that undersized. Guess I will have to forget about installing those neon chasis lights :lol:
OK, I was just kidding about the lights. I will stick to the mechanical pump for a while.
Trick6
Paul:
You would never throw a stone at any one. My point was that "I" wasn’t. You are the best. :savewave:
My comment is for those that are considering an electric fuel pump. And I do have a 55 amp GM alternator conversion. I have added electrical demands, fuel pump, cooling fan, and air horn. I think I will need to upgrade to a new wiring harness soon.
Brosky
Al,
It seems that you have just about everything.
Except...............
Those neon chassis lights mentioned above.
Now those would really make a statement when you're out at night cruising down around with BobbyD...........
T
Tinster
Brosky said:
Al,
<span style="color: #660000">Oh WOW!! Awesome They sell those neon kits right around the
corner from home, at the auto A/C shop we use.
I can just picture the envy of all the old Chevy guys as I drive
slowly past them parked in a line Saturday night in the Burger King lot.
They even sell LED tire valve stems!!
What a great concept!!! Paul, you are a wonder. And your fantastic fuel pump
is still pumping away in Amos!!
d</span>
Brosky
Just get a big old air compressor pump and some air bags for in the springs and you can have that TR6 hoppin' down to the biker bar!
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
A TR6 How many fuel filters-TR6 Triumph 25
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
G TR6 TR6 fuel tank fitting size. Triumph 14
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
