TR6 TR6 frame
BRSLimited
Looking at the Moss catalog it says there is a frame change from 72 to 73. Any ideas what the change was or is that just where they started doing the control arm mount reinforcement from the factory?
The "Framemeister" is in your section of the country, the Northeast. I recommend you contact the folks at Ratco.. If anyone can answer any questions about 6 frames, it is the guy at Ratco.
I believe that is also when they redesigned the area around the rear motor mount, to accomodate the new J-type OD.
from what I found in the catalog the only parts differences besides the frame itself is the radiator cross tube and the transmission mount crossmember. Just didn't know if there were any other major changes that you wouldn't be able to use a later frame on an earlier car or vice versa
Would anybody in the Michigan area happen to have a usable TR250/TR6 frame? I would prefer pre 73 so I don't have to deal with the transmission crossmember but I won't be picky.
