bigbadbluetr6
Now that I've came to the concusion that my head gasket is causing my false heating problem I have figured it is time to take the head off and replace the headgasket and do some head work. I'm planning on plaining the head to get some compression back into the engine and put my tri carb set up on the car. So my question is what can I do to besides plaining the head? Can I put bigger values in the head? Keep in mind I will just be doing the head and leaving the stock cam and crank in. What is everyones experience and opinion on doing this work? Thanks
