hondo402000
decided to drop the Differential out today, no\ problem, going to send it off to be rebuild, my question is on the half shafts. I read you can swap the half shafts from left to right to put the drive pressure on the opposite side of the splines, would it be wise just to swap the outer splines housings or should I swap the complete half shafts or do nothing but clean and regrease, and has any one drilled the shaft housing and intalled a grease nipple
Hondo
Hondo
