TR6 TR6 distributor suggestions?
ichthos
My distributor on my TR6 is so loose that it actually worked itself loose and stranded me half way to Spokane. One result is that it ended breaking the plastic part on the points that ride against the cam. I keep my car stock. Does anyone know of a source they were happy with in a recent purchase of a distributor? I am not always a fan of reproduced parts. Is this something I should get rebuilt, and if so, does someone have a source for me? Any suggestions would be appreciated.
Kevin
70herald
Yep, just send it off to Jeff. It will come back better than new, properly set up for your car. It isn't worth doing it yourself since the parts will cost as much as his expert repair and of course you need special equipment to set and check the advance curve.
DNK
Kevin- Take it from me who is completely opposite of you on the stock thing.
Jeff is the person you need. He will rebuild your dizzy to better than new condition.
T
Tinster
Jeff's the dizzy man!
Dale (Tinster)
Moseso
Oh what the heck! Just because everyone recommended Jeff at Advanced Distributors, I ought to be contrary -- but I can't.
One more vote for Advanced Distributors. Jeff's the MAN!
martx-5
Hey Moses, other then the loud shirt, when have you ever been contrary! :laugh:
Dale
Got the stock distributor for my J-H back from Advance Distributors last week and it is a beautiful thing. Almost too nice to install. And cost, considering what I sent him was very reasonable.
poolboy
I didn't think I had a distributor problem, but I like to tinker with things,so I sent my dizzy to Jeff to get the "micro adjustment" wheel. Thought while I was at it, go ahead and get it recurved.
What a difference to have that power kick in and pull that made. Yeah, I got the wheel,but don't fool with it much and when I do, I usually end up back where I started.
TonyPanchot
I concur did right on the mark with my recurve
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
A TR6 TR6 Distributor cap issue Triumph 4
smaceng TR6 TR6 distributor advance and retard hook up Triumph 6
I TR6 Correct way to tighten distributor on TR6? Triumph 1
I TR6 Distributor help on TR6 Triumph 5
G TR6 1974 TR6 distributor advance spring specs Triumph 6
B TR6 'Cutting-down' a TR6 distributor ? Triumph 26
W TR6 Tr6 1974 Distributor Triumph 7
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
veale001 TR6 TR6 Distributor problem........................... Triumph 39
J TR6 TR6 distributor info needed... Triumph 8
jerrybny TR6 69 TR6 Distributor Triumph 1
I TR6 69 TR6 distributor/vacuum advance/retard help Triumph 4
T TR6 TR6 distributor removal - tips on tach drive Cable Triumph 5
N TR6 Need TR6 distributor advance weight spring Triumph 3
jerrybny TR6 73 TR6 Distributor question Triumph 4
G TR6 tr6 distributor Triumph 13
tr6web TR6 Tachometer and distributor problem - '72 TR6 Triumph 6
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
