smaceng
So I have this 1970 TR6 which I am raising from the dead. I've got it started and it runs (sort of) after setting the way off valve lash. Next I will do a tuneup and set the timing by light at 10 deg. B.T.D.C. What should I do about the distributor retard/advance lines? Nothing is hooked up now. It has the temperature vacuum advance valve on the upper radiator hose, but no vacuum ports on the carbs. It is my understanding that there should be ports on the carbs for the advance and retard distributor lines, but nothing on mine. Should I get rid of the temperature vacuum valve? Is there a way to use either the brake servo vacuum line, or the crankcase ventilation line for the distributor advance? Any help would be appreciated. BTW, no tags on the carbs for identification.
Scott in CA
Scott in CA
