TR6 tr6 differential - need feedback!
KAllen
Getting ready to drop the rear end - just the mounts to unbolt how much does the little bugger weigh - can i just unbolt and grab it? Looks to be 40 pounds or so but I have the car on jack stands so my face is practically on the underside of the pumpkin.
kodanja
use a jack, there pretty heavy!
RobT
Yep - the shipping weight for mine was 75lb. Suprisingly heavy little critters. Please don't drop it on your toe (or anywhere else)!
K
KAllen
Yep - I had to use the floor jack - would not come off square - and it is surprisingly heavy - now got to clean it - may get the pressure washer going to fine clean it - Thanks for the input all!
Gonna be clumsy to put it back - not as young now! Might need to buy more tools like a tranny lift or something! Darn! Question for Brosky - did you por15 the whole unit? Pics look like it - I have some por15 left and more Hirsh miracle paint - anyone have comments on the miracle paint?
I like the colors on yours kodanja - looks cool!
kodanja
thanx (john deer yellow) /bcforum/images/%%GRAEMLIN_URL%%/banana.gif
KAllen while you have the unit out , you may want to inspect the mounts for any cracks. The mounting on these items are prone to wear. If ya see any cracks it may be a good time to weld them up.
K
KAllen
Thanks for the heads up - I have read about that - so I will be looking as I clean and paint the por15 or Hirsh miracle on the underside.
I had a forklift I painted JD yellow for a training flick we make - looked good - but I have been painting cars and motorcycle tanks for decades now. Probably gonna croak early from all the fumes I inhaled. Especially the urethanes. Had fun tho - so no regrets!!!
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] did you por15 the whole unit? [/QUOTE]
If it wasn't powder coated or couldn't get up and run away, it got POR15 on it.
T
Tinster
KAllen:
I just purchased a diffy and it weighs slightly under
70# without the rear plate.
tinster
kodanja
Can ya fit the differential in a microwave?
(With my Hot Pockets)
G
If you are going to tear it down (doesn't sound like you are), you might consider tapping the bottom for a drain plug. TRF rebuilt mine and did that as a courtesy. Not that one changes the Hypoy oil very often. Maybe Brosky would.
Brosky
Funny that you mention it. It was changed this time because I had the drain plug put in while it was out.
Never gave the drain plug a thought the last time it was out.
TR3driver
Great Pumpkin - R.I.P
Me too. O'course, the TR3A book said to change it every 6k miles; the concept of "lifetime lubrication" (where the lifetime ends when the lubrication wears out) hadn't been invented yet.
I don't do it that often (synthetic oil), but still every few years.
K
KAllen
I can always pump it out with the outboard motor lower unit gizmo - but a drain in it makes sense. That plug is hard to get to as I think about it back in the rear - so may not be able to use the Outboard mini pump. I have a tap/die set but I read that I need to use a plug with a gasket on a regular tap. Well - I gotta ponder whether its worth the hassle -
TR3driver
Check your tap & die set; frequently they include one pipe tap. If not, you can buy a pipe tap reasonably cheap from Horrible Freight or any tool store ($15 @ MMC).
Don't forget that pipe taps are sized differently ... ISTR the fill plug is 1/4" NPT even though the threads are closer to 1/2" across.
BTW, MMC also sells magnetic pipe plugs with a hex socket, which I like much better than the hex head versions sold by TRF et al. (Less chance of damage from a stray rock or offroad excursion, no reduction in ground clearance)
https://www.mcmaster.com/nav/enter.asp?pagenum=39
Pick up some PTFE thread sealant while you're ordering
https://www.mcmaster.com/nav/enter.asp?pagenum=3301
It not only helps with drips, but makes the plug easier to get out next time.
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
J TR6 TR6 Differential Rebuild question Triumph 6
L Wanted Tr6 differential Triumph Classifieds 9
B TR6 TR6 Differential Followup, and inspection questions. How do you know it's good? Triumph 2
B TR6 TR6 Differential bearings. Triumph 3
T TR6 TR6 Differential Ratios Triumph 8
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
SkinnedKnuckles TR6 TR6 Differential Rebuild Triumph 4
glemon TR6 tr6 differential seal Triumph 10
W TR6 TR6 Differential Question. Triumph 6
MTribe TR6 TR6 differential leak fix - what to do? Triumph 11
mgedit TR6 TR6 Differential Mounts Triumph 6
J TR6 Last TR6 differential question Triumph 16
R TR6 TR6 differential internal upgrade Triumph 0
H TR6 Tr6 differential backlash Triumph 2
Aeroken TR6 TR6 Differential Inner Shaft Seals Triumph 8
T TR6 What year TR6 did NOT have a differential oil drai Triumph 11
C TR6 TR6 Differential Oil Seal ? Triumph 0
tr6web TR6 DIfferential and support damage TR6 Triumph 20
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
