Hey all: New noise for me-sounds like the driveshaft is hitting something (tinktinktinktink), varies with speed, unaffected by braking or gear changes. Noise is occasional, but when it occurs it does go on for a bit.
No signs of drive shaft or half shafts rubbing on anything.
Recent work: Goodparts CV joint-ed 1/2 shafts and hubs.
Drive shaft U-joints check OK, rear brakes look OK.
___
I'm thinking the side bearings in the diff?
SO: the Q--Big deal to pull and replace the output bearings in the Diff? The shop manual @ 51.10.02 makes it look pretty easy.
Thanks, guys.
___
Thanks, guys.
