bigbadbluetr6
Lately I have been having problems with my TR6 running good. Attached is a picture of some sort of vacuum something, each carb has one. These have always been open. Lately they are hissing when the car is at idle and making it run a little rough. When I cover up the holes the idle smooths out a little bit.
My symptoms have been the car will run real rough for a few seconds and then run normal again. I blurp the throttle and then it runs good again. Sometimes the car will die at idle. Revs help out with this problem.
I have replaced the diaphrams, plugs, wires, coil, rotor, fuel filter and run some injector cleaner through a tank of gas. I have been putting in 91 octane. Any ideas why my car will have these periodic spells of running bad? I plan on attending the Brits in the Ozarks show this weekend so I do have a deadline. My next step of action is to replace the fuel pump.
My car is a 73 but it looks like the carbs are off of a 74. The tags say 3613.
Thanks
Eric
Thanks
Eric
