TR6 TR6 Carb Gasket Sealing
TR6Dan
Member
Hi,
I have a '74 TR6 with Zenith Stromberg carbs; should I install the carb bowl gasket and gaskets/spacer between carb and intake dry; or use gasket sealer?
Thanks,
Dan
poolboy
Please...dry.
The only place I use a dressing is Hylomar M sparingly on the gasket between the 'starter box' and body of the carb..... you have to be very careful not to over do it
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
R TR6 Trouble with TR6, carb now??? Triumph 6
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
T TR6 leaking carb TR6 Triumph 17
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
M TR6 TR6 Gas Leak From Front Carb Triumph 5
A TR6 carb problem 73 tr6 Triumph 10
W TR6 Carb plug TR6 Triumph 2
W TR6 carb question tr6 Triumph 1
R TR6 Tr6 Carb alway lean Triumph 24
T TR6 Rookie photo od TR6 carb cleaning Triumph 2
I TR6 Carb help please for 69 TR6 Triumph 14
I TR6 TR6 carb adjustment teacher needed Triumph 30
ScottTR6 TR6 74 TR6 Carb Triumph 5
TR6oldtimer TR6 What's wrong with this carb '73 TR6 Triumph 7
TR6oldtimer TR6 TR6 Carb Diaphragm Triumph 5
T TR6 TR6 carb rebuilds? Triumph 18
I TR6 69 TR6 carb questions Triumph 2
I TR6 69 TR6 more carb adjustment questions Triumph 7
mrv8q TR6 TR6 Carb measurement Triumph 3
N TR6 TR6 Carb Float Adjustments Triumph 3
I TR6 69 TR6 carb tuning help Triumph 8
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
N TR6 TR6 Carb spacers/Insulators Triumph 4
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
B TR6 TR6 carb tuning vs. HP Triumph 12
mrv8q TR6 TR6 carb "ball joints" Triumph 10
I TR6 Carb rebuilding/assessment 69 TR6 Triumph 6
I TR6 Source for good carb rebuid kit for TR6? Triumph 2
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
G TR6 Question for TR6 triple carb owners Triumph 21
AltaKnight TR6 TR6 carb euphoria! Triumph 3
I TR6 TR6 carb help Triumph 4
T TR6 Recommendation on '71 TR6 Carb Rebuild Kit? Triumph 7
SpannerMan TR6 TR6 Crankcase breather/carb replacement questions. Triumph 9
RomanH TR6 TR6 Zenith Carb Problem Triumph 5
AltaKnight TR6 TR6 ZS carb rebuild Triumph 4
Webb Sledge TR6 TR6 Carb to Lucas Injection Conversion Triumph 4
jerrybny TR6 73 TR6 ZS 175 CD-2 carb question Triumph 6
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
