This carbs are so simple that some problems may go unoticed. I have a tri-carb setup in my 72 TR6 Front and rear carb are well adjusted. The center carb is the culprit . It is insensitive to mixture adjustments. Even when the needle are set to full rich or full lean the spark plugs on 3 and 4 cylinder come out white (lean condition). I have check for vaccum leaks and everuthing is fine. Float levels are all set at 17mm. Shafts seals were replaced, diaphragm are fine. By pass valves are working. I have even checked if the needle fell of the screw and it is okay. The only sympton that I have noticed is some hesitation at full throttle on first gear.
Any ideas?
Any ideas?
