bigbadbluetr6
I am having problems with my brakes in my 73 TR6. I have posted once on this before but want to make sure I'm correct on everything. In my master holding tank there is black stuff. I think it is the seals in the master going bad. Is that correct? I'm thinking this is the major problem with my brakes. I just want to make sure it is not one of my brake calipers causing the problem. The brake on the front drivers side squeals when braking. On Sunday after I drove a while I had no pedal so I used a self bleeder on all wheels. The pedal got good enough(not great) and then had to rebleed my brakes on Tuesday because the pedal was mushy/not hard. On Tuesday I only bleed the front brakes and the pedal got good enough(not great) once again. Now I have to pump the brakes a little to get my pedal back to good enough. I hope all this makes sense. I am planning on rebuilding the master but am asking to see if there is something else that might be causing this problem. I've had master cylinder problems off and on for years now. Any help would be appreciated. Thanks
Eric
Eric
