TR6 TR6 Brake Issue
zmayne
I just upgraded my brake lines to stainless steel Goodrich lines and also used synthetic fluid. Took it for a test drive and now it feels like the booster is not working. The pedal is nice and hard, but makes a slight "poof" sound when I depress it and there is very little braking power. I did a hard brake test and the thing barely stopped.
Anybody experience brake booster failure after doing the upgrade I did? Also, what exactly does a failed brake booster feel like? Comments, criticism, etc welcome!
Thanks,
Zach
3798j
Bronze
Here's something you can try to determine if the brake booster is functioning: With engine running and foot firmly on brake pedal, turn engine off. If no downward movement of brake pedal is felt when engine stops (or a feeling of the pedal becoming more firm), it's usually pretty good sign that there is no vacuum assist.
TR3driver
Great Pumpkin - R.I.P
A better test is to apply and release the brakes several times with the engine off, then start the engine while you press on the brake pedal. If the booster is working, the pedal will sink slightly once the engine starts.
The booster doesn't touch the fluid; so it shouldn't be affected by changing lines & fluid. Sounds to me more like there is something else wrong, since it shouldn't be all that hard to lock the wheels even without the booster. Could the pads & rotors have gotten contaminated while you were bleeding the new lines?
TR3driver
Another thought, was the MC disturbed or replaced during the process? Sometimes the pushrod needs to be adjusted or replaced to accommodate differences.
davidk
Could the pressure differential valve shifting cause these brake problems?
TR3driver
Not unless it is clogged somehow. It never "shuts off" the flow of brake fluid, and in fact is not a valve at all. It only senses pressure differential, and closes a switch if the differential is high enough to move the piston.
John_Mc
I have the very same problem Zach. If I put too much pressure on the brakes, there's a "PFFFT!" and braking power goes way down and I have to quickly let up and reapply. I can do this at a stand-still and I notice that after the PFFFT the engine revs a little higher and I hear a hiss if I keep the pedal depressed, so I'm convinced it has something to do with the vacuum assist, but I have yet to resolve it. But I haven't really been trying too hard to resolve it yet. I'll share any discoveries with you as I make them.
hondo402000
sounds like a tear or hole in the rubber bellows inside the booster. if you have one of those hand held vacuum pump you can pull a vacuum on the port that goes to the manifold and if it wont hold your booster is bad
Hondo
Z
zmayne
Thanks for all the replies guys! I got busy over the holidays and forgot about this thread. I think I may have determined the problem. I went out to the garage two days after I first drove it and discovered that the brake fluid had all leaked out from the right front. I inspected the caliper and its totally blown, so that I believe is the problem.
I have a rebuild kit on the way for both front calipers, so we'll see how that goes. Ironically, I know what caused this too. A few months ago, I did a few laps at the local racetrack in the TR. On the way home, the right front bearing disintegrated on the freeway, so I lost the brakes and the front hub was literally warped from the heat, though I did manage to get it safely off of a VERY busy freeway.
I installed a new hub and bearings and had the rotor resurfaced and was back on the road. A few months later, the right brake line went, so in went the braided lines. And now the caliper goes. Guess I should have checked everything more thoroughly...
Chrisc9 TR6 TR6 brake light Triumph 6
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
J TR6 TR6 Brake Question Triumph 1
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J TR6 TR6 Brake Pad Shims Triumph 1
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
A TR6 '73 tr6 passenger front brake dragging Triumph 2
C TR6 TR6 with dot 5 brake fluid Triumph 8
sundown TR6 1973 TR6 brake booster hose Triumph 7
smaceng TR6 TR6 brake pressure balance valve Triumph 2
D TR6 76 TR6 New Brake Bleeding Triumph 4
D TR6 76 TR6 Rear Brake Installation Triumph 17
D TR6 76 TR6 Brake Servo Triumph 2
D TR6 76 TR6 Rear Right Brake Line Triumph 8
bobh TR6 TR6 Brake Upgrade Triumph 19
W TR6 TR6 brake pedal drip Triumph 12
D TR6 TR6 Puddle of Brake Fluid on the floor Triumph 8
M TR6 Tr6 Brake Pull Triumph 6
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
sundown TR6 TR6 e-brake Triumph 2
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
J TR6 70 TR6 Brake Booster Triumph 4
hondo402000 TR6 TR6 power brake bleeder Triumph 10
Phil73 TR6 TR6 brake issues Triumph 13
PatGalvin TR6 Need TR6 Brake Caliper Brackets Triumph 15
wangdango TR6 TR6 brake servo rebuild kit? Triumph 2
I TR6 TR6 brake squeal Triumph 8
bigbadbluetr6 TR6 TR6 Brake Problems Triumph 6
mabbott TR6 Brake fluid in 73 TR6? Triumph 6
T TR6 Anyone have a spare TR4/TR6 brake master lid? Triumph 4
I TR6 TR6 - how many brake caliper shims? Triumph 26
Brosky TR6 Really BIG Brake Kit for TR6 Triumph 15
I TR6 A few dumb TR6 brake questions Triumph 9
TR6oldtimer TR6 TR6 Brake caliper part. Triumph 6
TR6oldtimer TR6 TR6 brake calipers Triumph 6
TR6oldtimer TR6 TR6 Hand Brake Install Triumph 2
I TR6 Rear brake drum temperature TR6 Triumph 13
hondo402000 TR6 Front Brake issues TR6 Triumph 2
hondo402000 TR6 figured out my low brake peddle problem TR6 Triumph 1
hondo402000 TR6 TR6 rear brake rebuild Triumph 10
I TR6 69 TR6 brake booster Triumph 2
T TR6 Any tips for replacing TR6 rear brake lines Triumph 10
B TR6 TR6 Disc Brake rattle Triumph 2
AngliaGT TR6 Found the TR6 Brake Problem Triumph 5
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
F Brake and clutch fluid 73 TR6 Spridgets 9
