Originally posted by conehead53:
All of a sudden my 1976 TR6 is bogging down when accelerating. In experimenting, I found that I can alleviate this problem by pulling the choke out about one-third. However, it concerns me to have to do this. While I realize this may be a caused by a variety of things, I'm hoping this may be something simple to fix.
Going by the subject of your post, I'm surprise your engine hasn't blown to pieces!! LOL! I mean, "25 thousand RPM" is pretty dang high RPM - like maybe five times redline!
Ok, but seriously, I know that was a typo, but I couldn't resist. The first thing I would check is the oil level in your Carb Dashpots. If low, top it up. You can buy special oil just for those dashpots from places places like Terry's or XKs Unlimited, etc., But what I usually use is just a light motor oil (say, 20 weight). What it sounds like is that your engine is leaning out on acceleration. This can happen when the oil in the dashpots is depleted because, then when you accelerate, the piston in the carb lifts up too suddenly and allows more air than necessary into the combustion chamber, thus leaning it out and usually causing a hesitation or "bogging down."
But with the proper oil level in the dashpots, the piston/jet will raise more slowly under load, thus keeping the mixture right. I'm not promising that is for sure your problem, but that's an easy thing to check and fix if need be.
Check that and let us know how it goes.
1967 Jaguar E-Type OTS
1E13333, Silver Blue
[This message has been edited by Basil (edited 08-30-2001).]
