this quick cheap shock conversion has turned pricey ,then again don't all DIY projects--The Canadian Buck has dropped 20% since you stopped buying Canadian oil It's all this fricken fracken for oil you're doing--LOLCan I help you spend some more of those Canadian bucks ?
https://www.goodparts.com/shop/index.php?productID=347
i bought the set slightly used ,I believe they are the set sold through MOSSHi Terry, I just ordered a set of ago shocks for the rear of my tr6 that fit inside the springs. Is this what you are installing?
Are you talking about the Revington TR set up ( https://www.revingtontr.com/shop/pr...A229RWE9VB4&CarType=TR6&ProductID=RTR3003RJ2K ) or is it made by someone else? If it is made by someone else, care to share the source?
