When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
My window plastic vapor barriers are all tangled up in my window regulators making the windows hard to operate and I would like to know if anyone has ever left the barriers out or moved them outside the door frame behind the door panels. Thanks
Leaving them out will likely let water into the car, or at a minimum allow the door panels to get wet/damp. Putting them on the outside of the door seems to be pretty common actually, I'm planning on doing that soon on the '74 TR6 soon.
