grant tr4a
I would like to do a vacuum test, but I do not see anywhere to connect to the intake manifold. Has anyone figured out how to do this test on a 1966 tr4a. Thanks Grant
I believe the ventilation comment was about running the engine with the PCV valve disconnected from the intake manifold. If you leave it connected to the rocker cover, then pressure will build up inside the engine until the valve opens, which is probably not a Good Thing. If nothing else it tends to blow oil out of the joints and seals, especially the original non-contact rear main seal.I could use an education on why you're interested in testing the vacuum and why crankcase ventilation is an important issue. Wouldn't either the down-pipe or the PCV valve be adequate for an old LBC?
