I have a 66 TR4A with a top frame only and no top so I have no reference as to how the old top was installed and how to install a new (Robbins) top.
So, some questions.
It seems at the trunk end the top uses lift-a-dots and snaps on the two sides. If that's the case when having the top down do you unsnap the lift-a-dots and side snaps to install the tonneau cover or boot cover? I've had a couple TR6 and don't recall having to do that when the top is down and the tonneau is in use. Maybe my memory is faulty in that regard - please confirm.
Second question, the new top I have has an unfinished edge where attaches to the front frame header. From what I gather this somehow gets glued to the frame and maybe there are some channels underneath that gets riveted once glued? This is confusing to me and not sure how finished the top would look if only glued and riveted.
I've attached a picture of my frame - any help or better pictures of how your top is attached to the frame on the windshield end as well as showing those elusive channels.
Thanks
DK66
So, some questions.
Thanks
DK66
Hi Guest!
