When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
The kit I'm refering to is the type that bolts right on to the lever shock mountings. I've heard stories of this conversion failing somehow ripping metal in that area. Anyone know anything about this and what areas need to be reinforced? Pictures? Thx Karl
I have seen the brackets rip out of a frame on a TR4, however, the frame itself was in bad shape and the job should never have been done until the frame was repaired...which we did after the fact. With an IRS, I feel the better solution is the shock in coil setup.
