TR4/4A TR4A rack / inner tie rod adjustment.
Adrio
I have some play in my inner tie rods on my TR4A. Reading the service manual it seems to contradict itself.
Do I add shims or remove them to take away the slack in the inner tie rods (or inner ball joins as the manual calls them).
In one place it says "prepare a shim pack slightly larger then the ball lift" by which I assume you add shims to get rid of play. But later it says "if tightness occurs , increase the shim thickness sufficiently to overcome this." by that I assume you remove shims to get rid of slop.
I just want to know if I should order shims or will I just have to remove shims.
TR4nut
Just an opinion because I'm not in my garage and can't confirm, but I think you remove shims to tighten. I think the shims go under the large nut that holds the inner tie rod ball to the rack - removing shims allows the nut to tighten further, which brings the ball tighter to the socket.
Randy
TRMark
Looking at the diagram in the shop manual, it looks like you add shims behind the cup to take up the slack. It has been awhile since I shimmed mine, I think I used a dial indicator to measure the thickness of the shims required. I ordered thicker ones to get me close and bunch of very thin ones to get it exact. I think I have a few left over. On my sports/racer I removed shims from under the cap to tighten it up. I think that is how MGs are done. But I am not an expert.
TR4nut
I withdraw my earlier comment as I think Mark is both jogging my memory and stating the right way the shims work. Makes more sense as the large nut is on there very tight and has a locking tab arrangement - not conducive to shims I think.
A
Adrio
Thanks for the answers so far.
The bigger question I should have also asked is, can this be done with the rack still in the car?
TR4nut
Adrio-
What is still firmly in my memory is that the retaining nuts for the inner rods are on extremely tight - I expect that you could do this service without pulling the rack, but getting the retaining nuts apart will be the battle.
Randy
TR3driver
Great Pumpkin - R.I.P
Definitely need the skinny wrench to grab the inner flats while using a second wrench to turn the big nut. Putting all that force against the rack & pinion will almost certainly break something; leaving you with much worse problems than a loose inner tie rod.
As I recall, I couldn't find a suitable wrench on short notice, so I bought a cheap wrench from HF and milled it thin enough to fit. But that was on a Stag, your 4A may be different.
TRMark
I would not attempt it in the car. It is much better on a workbench at a proper working height with less dirt. You will probably assemble and disassemble it a few times adding or removing shims to get the proper fit. As Randy stated these pieces are torqued very tight.
A
Adrio
This "little" job is getting bigger and bigger. how much work is it to remove the rack, in terms of time?
TR3driver
Bound to be easier than on a Stag!
Not sure, but ISTR on a TR4A there is a special tool involved to hold pressure on the rack clamps while tightening the bolts as well. (Yeah, I know, no one uses the tool, then they complain that the rack moves in the clamps.)
Unless pulling the rack is really easy (or you want to adjust the pinion while you're at it), I'd just go ahead and do it on the car. Once you've collected the right tools, it's not that bad. And if the boot is in good shape, you don't even need to remove the outer end.
TRMark
Not sure about the special tool for the 4A, mine is a 4. You might be able to separate the inner joint from the rack in the car again sometimes this things are really very tight. If you don't feel the need to pull the entire rack, you are ahead in the game. As far as shims adding or subtracting, you will find out for sure when you get the inner joint disassembled. I thought that the earlier aluminum rack mount could be used instead of the later rubber mount to eliminate the play. I know there are kits available to do that. Hope I am not "steering" you wrong on this, like I said it has been awhile.
T
TRDejaVu
It can be done in-situ, but obviously easier with the rack removed. Don't make it too tight as the ball will break; ask me how I learned this over 30 years ago.
T TR4/4A Compressing steering rack bushes - TR4A Triumph 12
T TR4/4A Fitting a sway bar to a TR4A & steering rack Triumph 5
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
Rut TR4/4A TR4A parts car Triumph 7
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
michalotti_tr For Sale TR4A Project Triumph Classifieds 18
Sarastro TR4/4A Original TR4A paint: enamel or lacquer? Triumph 4
KVH TR4/4A Wiring to TR4A Wiper Switch Triumph 11
S TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
Rut TR4/4A 66 TR4a on BAT Triumph 4
J TR4/4A TR4A clogged fuel filter Triumph 13
T TR4/4A TR4A/TR250 what are they worth Triumph 8
N TR4/4A TR4A windshield replacement Triumph 1
AngliaGT Tr4a Spotted 0
Brinkerhoff TR4/4A Straightening a TR4A IRS chassis Triumph 15
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
K For Sale TR4A Grille...Modified for Lights Triumph Classifieds 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
J Wanted Tr4a irs frame Triumph Classifieds 1
S TR4/4A Smoothline hardtop for TR4A Triumph 0
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
