TR4/4A TR4A - piecing the dash back together
TR4eh
Slowly getting parts back under the dash. I came across three holes in the plenum, one with a captive nut and the other two just 1/2" holes in the sheet metal. To quote Gandalf - I have no recollection of this place. They are just to the passenger's side of the heater mounting. Anybody recognize what goes in these spots? Tubing from the windshield washer pump, perhaps? The theaded hole is not for the heater, of that I'm sure.
Thanks very much,
Cliff
Just a guess -- when I find possibly unused holes or fittings I look to see if the same thing appears and is used on the opposite side. Several aspects of these cars were set-up to be used for either LHD or RHD as required.
I would have to say one of them is the water line for the wiper misters & the other is for the small rod that operates the
vent (scuttle). Mines covered by the glove box so I can't check it out. I've found out the best way is to forget about these
little things & they generally come to mind AFTER you put a part on that needs to be removed ! Don't ask
Harry
Harry
Harry, that makes a lot of sense. I had forgotten about the scuttle rod. That threaded hole will reveal its purpose in its own due time, I guess.
