boeingpilot
There was a thread a wile back concerning the possibility of a bad PCV system pressurizing the crankcase and forcing oil out the real main seal. Can't seem to find it, but as I recall someone had some luck with getting rid of the system and stopping (or nearly stopping) the oil leak. My 4A also leaks from the rear main seal, not a terrible amount, but enough to leave its mark. I was going to try this fix myself, but had a question. If you cap off the port on the intake manifold does there need to be a mixture adjustment as well? Seems to me plugging that port would alte the fuel/air mixture?
