rlich8
Hello all,
My TR4A was converted to OD at some point, which is great. The switch is proper and the OD works great, but I have a few questions.
The OD is supposed to operate in 3rd and 4th gear only, correct? I can switch it on and off in any gear (including reverse! EEK!), which I know is not right!
I am suspecting 1 of 2 problems:
1. The lockout switches are incorrectly wired and perhaps the circuit is closed all the time.
2. The shift tower somehow got swapped from a standard non-OD transmission, thus, there is no switching.
Also, where is the overdrive relay usually located in the TR4A? In the TR4A, is the overdrive harness built into the main wiring harness of the car? How many switches, total, should be on the transmission? There should be a switch on 3rd, and 4th gear, correct?
Thank you!!!
Thank you!!!
