TR4/4A TR4A Just Curious
JDstr4a
Rebuilding the original antenna which was snapped off. the cable was forced between the rubber gasket under the dash which didn't seem right. Looking through the exterior mounting hole noticed something through the hole I didn't recognize. Tried to find a reference with no luck. Sorry for the poor quality photos shooting through the antenna hole. What is it?
JD
sail
Looks like might be part of the antenna bracket. Can't you get to it partially removing the passenger side footwell panel?
J
JDstr4a
Exactly what it was. I didn't hear them fall when I disconnected everything and they way they fell seemed like they belonged there :wall: A magnetic pickup and hemostats got em out. Spent another 20 minutes looking for a nut I thought should be on there. The good news, I got it all back together and reconnected the drain tube for that area while under the dash. Now just need to figure out how to route the antenna wire.
Thanks again.
JD
KVH
I'm curious what kind of radio you're to install. I've got an original TR radio, but I have to send it out for repair. New ones form Moss and others work better, sound better, offer more options, apparently fit OK and don't offend too many sensibilities.
J
JDstr4a
Not sure if this radio is orginal or not (assuming it is) currently not connected to power. I just started on the antenna cause it was coiled up on the passenger floor and the mast was broken. Once I get the cable routed I'll hook up power and see what happens before I remount the speaker. Too many other things on my list to consider audio upgrade at this time.
JD
Mickey Richaud
Hey, JD -
Looks like it may be original to your car (as a dealer item). Radios in the fifties and until '63 had a little triangle and "CD" at each end of the dial for the "Conelrad" emergency warning system.
Certainly appealing to keep your car period correct!
J
JDstr4a
Thanks Mickey, ahh yes civil defense, get below your desk and cover your head against that nuclear explosion! Not sure what the BC/KC are, guess I'll have to Google!
Mickey Richaud
KC = kilocycles (now kiloherz)
BC, if memory serves, stood for "broadcast"...?
J
JDstr4a
The rabbit hole is deeper than I thought. Since raining today, pulled the radio to get model number
etc, and as soon as I tilted it rattle rattle. took off the inspection cover and viola spare parts!
Maybe time for a blanking plate :smile:
JD
TR3driver
Great Pumpkin - R.I.P
If you feel like trying, any decent electronics shop (maybe even Radio Shack) should have a suitable substitute for that capacitor. However, polarity is important and you may have to do a little detective work to figure out which trace on the PC board is positive or negative. Chances are, though, that the negative lead went to ground and it will be easy to follow the trace around the board until you find a place where it connects to ground.
There is some chance I might have some information on it at home, I'll try to check tonight.
J
JDstr4a
Thanks Randall. I've spent the last few hours scouring the internet for a diagram, with limited results. Old radios like this used to have diagrams on the inside, so tonite I need to clear the bench and make a clean work area to tear it down. As I recall the cases are like a puzzel to take apart,seems to be in solid condition other that the cap, looking at it closely it doesn't seem burnt anywhere so we shall see...
JD
mclaugh
JD,
I'm sure you have discovered that you can buy a SAMS manual. It wouldn't surprise me if someone here has a collection of those and could send you a copy. But you probably don't need one real bad. A cap that big left a big space, and it shouldn't be hard to see where it came from once you get the entire board exposed, which you'll need to do anyways to solder a new one in.
-Why did it fall out? If from corrosion, you'll probably have to repair the circuit board also. It looks really clean inside though.
-Big electrolytic capacitors are usually used as power supply filters, or sometimes to couple the output of the amplifier to the speaker. Either way, the capacitance and voltage are not critical and can both be larger, the only problem is to find something that will physically fit.
-If you can't find one locally, try Mouser or Digikey online.
-Of course, there could be something else wrong once the cap is replaced, but it's the obvious place to start. Keep us posted.
BTW, thanks for the clear pictures.
-Tom
mrv8q
Applause from the gallery! Well done, Randall!
J
JDstr4a
Found the space which was pretty easy as Tom suggested
Confirmed by Randall's pictures, component side picture even shows stripe for polarity! Just need to find a replacement and my solder sucker. Thanks Gentlemen!
JD
J
JDstr4a
Dang it! relaced capacitor, got light when connected to power, resoldered speaker wires, remounted speaker, put in radio and nothing! Speaker impendence ok and noise when checking, miliamps out of radio, but not even static. guess I'll move on for now and start checking for a period correct radio to swap out. :cry:
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
