TR6 TR4a IRS vs TR6 handling
Back to Skip's original question, if the TR6 and the TR4A are setup the same with the same poly bushings, same sway bars and same tires, then they should handle the same, correct? The geometry is pretty much the same, all the suspension, brake and drivetrain parts are interchangeable except for the engine and master cylinder, so they should work the same, right?
Dan B
