Stinger
Removed and marked all the gauge wiring when we replaced the wooden dash. Put all the wiring back as marked. Everything lights up except the temp,fuel, and amp illumination lights. There is a three wire ground going to the top stud of the oil gauge, then a common ground wire starting at the temp stud,to the bottom oil stud, then on to the fuel and amp. When we run a jumper from ground to the temp, all gauges light up so we know its a ground issue but cant seem to figure this one out. What are we missing?? Thanks
