DavidLayton
Had a leaking fuel pump which I replaced with a repro from Rimmer Bros. The repro had the priming lever which was not on the one I removed.
Installed the pump. It appears not to work, only running off the prime. I am assuming that the cam and the lever are not making contact. Not sure why this is, it seemed to be a fairly simple connection.
Now one area of difficulty on this is the lack of a fuel shutoff which means that fuel will shoot out the fuel line once it is disconnected from the pump. If I have to detach the fuel pump, how do I deal with this?
Thanks!
Thanks!
