TR4/4A TR4a engine compression
Rrbbeerrttoo
Banned
Does anyone have answer to cylinder pressures; it will be appreciated.
My Tr runs great at all speeds, except for my continuing problem with strong fuel smell and maybe fuel mixture adjustment. But my question today is :
1. I pressure tested all cylinders, just to know the answer . All four fell within 149-150 psi. Is this normal for piston/rings with 50,000 miles. If not , what should it be?
2. I do not see the answer in my car manual, except that under Performance Data it shows: 100HP @ 4600 RPM; Torque, 1520 psi at 3350 rpm ( equivalent to 145 psi BMEP).
3. Is the above 145 psi my answer...I figured No! What does BMEP mean?
Thanks for any information.
Robert
Dale
Brake Mean Effective Pressure. Which isn't much help is it? Your compression readings are good in that they are so consistent across all four cylinders. I don't know if there is a factory recommendation or not, but 150 sounds pretty good.
TR3driver
Great Pumpkin - R.I.P
As noted, the actual pressure reading isn't so important; just the comparison between them. All between 149-150 is outstanding, much better than I would expect after 50,000 miles.
BMEP has basically nothing to do with compression gauge readings; it's just measured torque divided by displacement (with suitable scaling to psi).
glemon
As the others have said the compression readings are great, good number, great consistency, means your rings and valves are doing what they are supposed to do.
The gas smell, if there is a way out gas will find it, if coming from the back check the sending unit on the top of the tank, and fuel line running to the carbs (you will need to take the back panel out of the trunk for the sending unit, and get under the car for the fuel lines)
If from the front should be either the lines or the carbs. Could be pump, lines from tank to pump to carbs, carbs, includnig overflowing float bowls or leaky float bowls. Do you have SU or Stromberg carbs?
R
Rrbbeerrttoo
Banned
Thanks for the responses.
I have Stromberg Carb. And there are no signs of fuel leakage on the carbs, only fuel smell after running the car, and two hours after! Neither can I find fuel leaking or fuel wet spots anywhere , from the tanks to the Carbs or anywhere in between. Yes, I did inspect the fuel float area into the tank.
Have not disassembled carbs to check carb float level as I considered it impossible for internal float valve overflow to cause the smell..or am I wrong? If wrong, and have nothing else to check, SO, should I tear into the carbs?
About BMEP, thanks to all. I should not have asked , but googled instead , as I do other things.
Robert
poolboy
I wouldn't just tear into the carbs, no, but you could remove the air cleaner or whatever you have to do to see inside the carb's mouth.
The jet extends down into the float chamber and if the carbs were overflowing due to the needle valve or floats in the float chamber, I'd think the excess gas would show up first pooling on the bridge, where the metering needle enters the jet.
R
Rrbbeerrttoo
Banned
Thanks poolboy,
I have been running w/o air filters to quickly inspect if fuel pools as you described, but the bridge/needle junction looks clean immediately after parking.
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
KVH General TR TR4A Engine Won't Start Triumph 34
Zimmycobra For Sale Misc. External Engine Parts - 1966 TR4A Triumph Classifieds 1
Popeye TR4/4A TR4A rear engine lift point - photos? Triumph 14
S General TR Engine Serial Number Question - Observation on a TR4A Triumph 3
H TR4/4A TR4A engine mounts Triumph 4
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
T TR4/4A Fired the 67 TR4a IRS engine today Triumph 5
T TR4/4A Date range for this TR4a engine Triumph 8
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
T TR4/4A TR4a engine mounts - round vs rectangular & vendor Triumph 13
CinneaghTR TR4/4A TR4 v. TR4A engine mounts? Triumph 4
TR4nut TR4/4A Engine upgrades from a TR4a - what to get? Triumph 11
P TR4/4A TR4A Engine Misfire? Triumph 5
Paulus TR4/4A TR4A Engine runs on Triumph 11
PeterK TR4/4A TR4A engine block tag Triumph 2
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
