Rrbbeerrttoo
Banned
Does anyone have answer to cylinder pressures; it will be appreciated.
My Tr runs great at all speeds, except for my continuing problem with strong fuel smell and maybe fuel mixture adjustment. But my question today is :
1. I pressure tested all cylinders, just to know the answer . All four fell within 149-150 psi. Is this normal for piston/rings with 50,000 miles. If not , what should it be?
2. I do not see the answer in my car manual, except that under Performance Data it shows: 100HP @ 4600 RPM; Torque, 1520 psi at 3350 rpm ( equivalent to 145 psi BMEP).
3. Is the above 145 psi my answer...I figured No! What does BMEP mean?
Thanks for any information.
Robert
Robert
