TR4/4A TR4A Door Check Strap Spring Clip Replacement
Stinger
Is it possible to replace the door check strap Spring Clip without replacing the rivets? Thanks
Rrbbeerrttoo
Banned
Stinger,
No, I have no answer for you...but I will add this comment as someone may show us the way:
When I restored my TR4a it seemed impossible to figure out how to replace the door straps , even when I had the car 100% disassembled. However, there has to be a way!!
JerryVV
While we are discussing this is there a best way to peen the rivit. My body man replaced both of my straps. It looks like he needed to bend some metal on the back side of the A post as there is some bending that took place there. So that may be the trick to installing new ones. Cannot guess why this is so when new they didn't need to do any bending. Perhaps repo parts are enough different as to require this or somehow they went in a different way......like before the post was welded to the body. Only guessing.
JVV
Stinger
Stinger
My straps are ok its just that one of the spring clips is broken. It looks like it is attached by two rivets. I have ordered a replacement clip and will report back on how I replaced it. Im not sure how you would peen the strap rivet but if the rivet is soft enough you may be able to use a C clamp or something similar to flatten it out.
dklawson
Is the TR4 check strap different than on other TRs? On the cars I have worked on there is a rivet holding the strap to the front of the door. The strap passes through a plate on the body tub at the front of the door opening. The two spring clips are riveted to the front end of the strap.
When I have replaced straps, I have drilled out the rivet at the door so the new strap could be fitted. When I put the new strap on I replace the rivet with a 1/4-20 round-head screw and a thin jam nut (with Loctite-721 (red) or -680 (green)). The round-head screw is bigger than the rivet but still small enough to fit through the hole in the body tub.
I have also taken parts of broken check straps and salvaged them. You can drill out the rivet holding the spring clips to the strap and replace them with a 10-32 machine screw and nut.
Sarastro TR4/4A Puzzled about TR6 door seals on a TR4A Triumph 7
N TR4/4A TR4A door crash pad Triumph 11
K TR4/4A TR4A door gaps again? Triumph 6
D TR4/4A TR4A Door latch mechanism issues Triumph 2
M TR4/4A Tr4 Tr4a door handles Triumph 2
Stinger TR4/4A TR4A Stainless Door Trim Question Triumph 5
Stinger TR4/4A TR4A Door Vapor Barrier Triumph 2
Stinger TR4/4A TR4A Door Waist Seal Tool Triumph 8
K TR4/4A TR4A window/door crank handle removal? Triumph 11
rovernut TR4/4A Holes in top of TR4A door Triumph 7
K TR4/4A TR4A interior door panel removal? Triumph 3
C TR4/4A TR4A door noise and road pop Triumph 6
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
Rut TR4/4A TR4A parts car Triumph 7
M TR4/4A Reducing Chassis Flex on TR4A IRS Triumph 2
jfarris For Sale 1967 TR4A IRS $19,000 Birmingham AL Triumph Classifieds 3
Rut TR4/4A 67 TR4a irs to live axle Triumph 18
michalotti_tr For Sale TR4A Project Triumph Classifieds 18
Sarastro TR4/4A Original TR4A paint: enamel or lacquer? Triumph 4
KVH TR4/4A Wiring to TR4A Wiper Switch Triumph 11
S TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
Rut TR4/4A 66 TR4a on BAT Triumph 4
J TR4/4A TR4A clogged fuel filter Triumph 13
T TR4/4A TR4A/TR250 what are they worth Triumph 8
N TR4/4A TR4A windshield replacement Triumph 1
