TR4/4A TR4A Differential Lube
KVH
OK, I finally replaced the Differential lube with GL4 due to all the picky picky folks here telling me I might ruin my gears.
The manual says the capacity is 1.8 pints. But I've put in over two pints to get it right below the filler plug hole.
Am I too full? Must I drain some out?
Do you have it level front/back and side to side?
Personally, I wouldn't worry about it. A little bit extra won't hurt anything, and a lot extra will just get thrown out the vent.
But then I also use GL5 :laugh:
Andrew Mace said:
That manual might be measuring in "Imperial" pints.
That was my first thought too, but I checked two different sources and they both give 1.5 Imperial pints and 0.8 liters, as well as 1.8 US pints. Could still be a misprint that never got corrected, but at least KVH read it correctly.
