DrinkingWhisky
A quick question for you all as I recently noticed something while I had the car up in the air. I recently replaced all hoses for the cooling system using Roadster factory parts. From the water pump outlet back to the radiator (I believe that's the circuit), the rubber hose routes into a metal pipe and then back to rubber into the radiator. (see #19 in MossMotors diagram) https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29120
I've noticed that there is a slight rub on the rag joint now as I turn the wheel. no rub, no rub, no rub, .. rub.. no rub, no rub, no rub, ..rub.. as I turn lock to lock.
Anyone have this issue? If so, what did you do to fix it? I'm thinking of shortening the neck of rubber pipe #17 (MossMotors diagram).
Thanks all!
Thanks all!
