TR4 OD
The OD and main shaft are new (used) to me. When I try to assemble the OD to the transmission, even with the pump cam and springs removed, there is a gap of about 1/8" between the tranny and the adaptor plate. It looks as tho the mainshaft has been modified. Does anyone know what the dimentions of the main shaft are? From the output bearing retaining ring grouve to the end of the shaft and to the end of the splines? The OD showed evidence of a very thick gasket when I recieved it. OD SN 22/1274/00498.3
Thanks for any and all help. Dick
