TR4/4A TR4 license plate bracket location
SCguy
I'm not sure where this bracket goes. I could eyeball it, but I'm considering getting an amco luggage rack for the car and I believe that I need to make sure the bracket is properly located before I drill. Can any one provide me with a correct measurement of where to drill and locate my bracket?
Tomster
My 4A has two nutserts installed thru the lid, either side of centre and approx 1 - 1.5 inches above the handle of the boot lid. This provides mounts for the lower portion of the plate only, which seems fine. I also backed my plate with rubber to lessen any scratch risk to the lid it self.
The thought of drilling thru that lovely paint must be terrifying. Put some low tack tape for marks first and then measure and measure and measure then mark. Go have a beer, think about magnets instead.....
Geo Hahn
Mine has no bracket -- just holes in the boot lid for the upper license plate bolts:
I made some rubber washers to protect the paint there.
I'm confident that these holes are original as the car has original paint and those nuts had the same funky grey plasticene on them that were on the other bolts and speed-nuts and that a former TR employee assured me was the original goo.
I would be concerned that that bracket would not stand up to the weight you will put on the luggage rack with a suitcase or such.
Nervous work drilling in fine paint. The guy who did my TR3A thoughtfully welded up the holes for the rear 'TRIUMPH' badge and I got to measure and drill the replacement holes.
Sorry, I am away from home and cannot give you exact locations of the holes on mine.
PS - With that bracket standing proud of the surface of the boot lid I'm not sure the luggage rack would even mate up with it properly -- I'm thinking the rack 'legs' want to be mounted against the surface of the boot lid.
Merlin63Tr4
Larry, I have an AMCO luggage rack on my Tr4, and there is no way that sheet metal bracket in your picture could support the luggage rack.
My '63 came (like Geo's) with only holes thru the trunk (boot) lid, but unlike Geo's mine has all four holes for mounting the license plate. I also added rubber spacers between the license plate and the paint to protect the finish. The luggage rack uses the two upper license plate holes for locating, mounting and supporting the rear, and there are two small brackets that slip under the trunk (bonnet) lid hinges to mount and support the front of it. /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
Tomster
Rubber "O" Rings sound like the way to protect this area. Plumber's O or donut rings would be easy to source.
My luggage rack has 4 mount holes thru the horizontal (top) surface of the boot lid only. It is not one of those, Dali inspired, drooper racks
Geo Hahn
If you go with that Amco-style luggage rack -- which is a quite elegant no-drill design -- you might consider reshaping the hinge mounts a bit so they look a bit more attractive. These before & after pics show how I changed them:
TRMark
Bronze
Is this what you need? There is no bracket the holes are drilled into the lid. Like the grommet idea. Always good advice; measure twice.
H TR4/4A License Plate Bulb Holder On TR4 Triumph 6
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
