bluemiata90
I just purchased a 65 TR4 that hasn't been running for several years. Prior to being stored, the head had been rebuilt and replaced (hopefully timing chain replaced correctly). After doing all the things you need to do to start an engine after a long storage, I fired it up. It started almost immediately and after a little fine tuning stayed running for me to drive it, but it really doesn't run smoothly, so I'm attempting to adjust all the needed settings. The problem is, setting the ignition timing correctly. I can get the timing hole lined up with the marker, but the #1 piston does not seem to be at TDC and the distributor rotor is slightly off the #1 plug hole. If I move the crank about 1/4 turn further, the piston reaches TDC and the rotor lines up perfect with the #1 plug hole. Is this normal and should I just paint another mark on the crank pulley and adjust it to that mark. Also, how do I figure out the advance degrees to set it at. If anyone can help me I'd greatly appreciate it. /ubbthreads/images/graemlins/confused.gif
scott
scott
