Alan_Myers
Hi all,
This evening I've been test fitting a new exhaust system on my TR4 frame and I have a request. Would anyone be able to measure - without too much trouble - the distance between the very bottom of the gearbox bellhousing and the bottom of the outer frame rails?
The reason is that my engine is still on a stand, awaiting flywheel and clutch balancing and a few dozen other things. But I've temporarily bolted just the gearbox/OD back onto the frame to check clearance. The exhaust is running *very* close to the overdrive. I'm hoping the dimension, lowest point on the bellhousing to lowest point on the main frame rails, is around 1.5" or more.
On the subject of exhaust, has anyone installed an exhaust system rigidly, without all the rubber hangers? I will be using a flex fitting between the header and the rest of the exhaust, so engine torque wouldn't be a problem. The reason I'm asking is I remember the loud "clang" my old exhaust used to make every time I went over a bump. Besides engine torque, and perhaps some additional resonant noise inside the car, and concerns about dragging low parts of the exhaust, are there other reasons most systems are rubber mounted in some way?
Unfortunately, I found a problem with one of the handbrake actuating levers in my car. The pivot pin in the lever (which passes through the rear drum backing plate and pushes the shoes to engage the handbrake) is normally press fit, but I've discovered one of mine is loose and slowly chewing up the inside of the hole. I tried to drill a hole at 90 degrees, to drive something in from the side and trap the pin in place. It worked drilling through the lever, but even a cobalt drill won't make a dent in the pivot pin. Must be incredibly hardened! I'm attempting to weld the pin in place, then grinding & file everything back into usable shape. But I sort of doubt I can get it into good enough to do the job. I've checked TRF and they don't stock replacments. Does anyone have a spare?
Other progress: I've got many the brake lines run, all the fuel line anchor points are ready and awaiting AN6 line to arrive. Front suspension is nearly complete, awaiting new Konis that are on backorder. The front calipers are both rebuilt, freshly painted and reinstalled, although I'm awaiting brake pads. The steering is back in, complete with a rebuilt rack that I'm adjusting and new tie-rods.
A quick check of the modified front geometry looks like I'm managing to get the half to one degree of negative camber I was trying for, caster and toe-in appear close but all three will still need to be confirmed with a proper alignment once the car's all back together.
Rear axle is now stripped out of the old frame and getting cleaned up and checked out. There's a limited-slip unit for the diff sitting on the shelf, but awaiting a 4.1:1 gearset before tearing it all apart.
I'll be test fitting the rear axle/diff with the exhaust, too. Looks to be a close fit there as well. New rear springs are on, although I plan to swap out the rubber shackle bushings for a poly set that arrived today. One lever shock has been gone through and tested okay. The other will get it's 40 years of grease and road dirt removed in the next day or so, but seems to be working fine.
The remaining rear brake parts I needed arrived today, except for alfin brake drums that are promised soon. The old drums are surprisingly good, though, and can serve in the meantime. The only "glitch" is the parking brake lever mentioned above.
Both rear axles look excellent, although seals will all need to be replaced and I'll certainly go ahead and install new bearings at the same time. Drive shaft is ready to go with new u-joints installed, new high tensile bolts and all-metal locking nuts arrived today (6 of the 8 old bolts I removed didn't even require a wrench, their nylock nuts had given up completely! Scary!)
Oh, and an oil cooler take-off with integral thermostat arrived today. Fits great and that's another item checked off the "to do" list. Now for the plumbing!
Whew! Still loads to do! But it's sure fun when things start to come together and it actulaly starts to look vaguely like a car again!
Cheers!
Alan
Cheers!
Alan
