TR4/4A TR4 Cooling Fans
KVH
Plastic was available in 1962. So, why did Triumph use a four blade steel fan?
Stated differently, if a plastic six or eight blade fan is so great, why wasn't that the spec?
doughairfield
That's a great question, one I've pondered myself, dying to know the answer too. Is there a plastic fan conversion for the TR4 that's worth a hoot?
TR4nut
The higher pitch TR6 fan has worked very well for me in the Houston traffic. With the metal fan, I just didn't pull as much air into the radiator when idling and I overheated quickly. Now I overheat slowly!
But a possible theory on KVH's question - plastic may have been available, but they may not have had a good polymer system back then that wasn't too brittle so it didn't take off til the late 60's - or maybe the good stuff was too expensive early on so the metal fan was cheaper.
I think a separate question might be why didn't they put the higher pitch tropical fan in every car?
TR3driver
Great Pumpkin - R.I.P
Because they suck more power; and Triumph/BL saw no reason to change. At the time, plastic was looked down on as 'cheap' (with some justification); and the stock cooling system was considered adequate.
BTW, my 95 Buick Roadmaster Estate with HD cooling & trailer towing package still uses a metal fan. There's nothing wrong with metal.
Geo Hahn
And of course that engine was around long before plastic fans were in use (around I think even before the TR2) so perhaps we simply inherited it. Anyway, a Ferguson tractor could hardly have looked right with a plastic fan.
S TR4/4A TR4 Cooling Triumph 4
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
