I have been following the wiring instructions from the article from Dan Masters on the VTR site i installed a geo tracker alternator 55 amps it has a 3 wire plug on the back and the main power terminal where the brown and yellow wire goes along with the sense wire. At the voltage regulator end i connected the small brown yellow brown green wires together, then the large brown yellow brown white and brown blue together, my problem is the ignition light stays on when the engine is running and the amp meter only shows a discharge there is voltage at the maim power terminal at the alternator. The small green brown at the alternator end connects to the the IG terminal i still have an extra wire from the alternator plug not to sure where to connect it to could this be my problem? Thanks Hughv
