CinneaghTR
Okay, got the new hoses, figured out the bend in the radiator pipe is toward the bottom, and have test fit everything. I either get a rub from the lower steering coupling or the steering rack mount. Is there a trick to getting the pipe lined up without touching anything? I fastened the top hose connection to the water pump housing and put antiseize on the pipe and hoses so I can slide everything back and forth until I get it right.
Doughairfield shared his experience the other week and I have his thread for reference, too.
Thanks!! (and I still plan to follow up on all the other loose ends I've been asking you guys about...)
