TR2/3/3A TR3untapped power from SU needles re Oxygen Sensor
karls59tr
Bronze
I read an article about TR3s discussing how, even if the motor is running fine , the Su's can still be too rich at idle and too lean on acceleration. The upshot was that if an 02 sensor was installed it would provide info to dial in the exact type of SU needles that would really wake up the power. Anyone installed an 02 sensor..what type? any advice? I use my 3 for fun driving and maybe autocross. Have a mild cam and header. I realize that doing head work is the best way to increse power but I'm intigued by the notion of the right SU needles maximizing my existing mods. Karl
PeterK
I think that by using the data from an O2 sensor you could reprofile the needle for the power curve of your engine with the mods you have done. I don't know how you would read the data though.
Somewhere I have the SU needle profile that shows the shape of the needle and how each portion is related to flow. So at (rich) idle, you would leave it thicker to keep it leaner, then thinner to lean it out, etc.
BTW. I drove my TR3A in it's first autocross this weekend. It screams off the line leaving rubber and more rubber as I shift into 2nd. I've chirped it in 3rd before but at an autocross, you rarely get that fast. This is with the stock SUs, no headers but tuned correctly. I won a trophy for Fastest Vintage Car in the vintage class of 2!
Dave Russell
Yoda - R.I.P
Re: TR3untapped power from SU needles re Oxygen Se
The O2 sensor only gives part of the needed information. There is no correlation between throttle position & needle height/step. SU needle calibrations/diameters are given in .100" height intervals.
I think the trick/problem is in knowing exactly what step the needle is actually on for a given engine load-throttle setting. The carb pistons move pretty much independently of carb throttle position. ie. - full throttle at 2,000 rpm will give a much different needle height than full throttle at 5,000 rpm.
If you could run on a dyno, you could get a pretty good correlation between piston/needle height, rpm, & load. Or, a linear position transducer on the piston would be one way to determine needle positions under actual driving conditions.
Most folks just determine workable needle profiles by trial & error or some one elses experiences..
PeterK
Try this link. Enter your current needle. eg. TR2's used .090" FV(street) or GC (competition) and is the number stamped on the base.
https://www.mintylamb.co.uk/suneedle/
Also this link https://www.teglerizer.com/sucarbs/index.html
You can use the teglergizer needle profiler to sort by station (the .090" or .100" band of the needle profile). Then select a needle that gives you more of what you need in that station, and then model it in the first link program. and visually see the effect in RPM range.
BryanC
I really think you need a dyno to tell if you're making any progress. Since the dyno guys will have a wideband O2 sensor they can hook up when you are there, you wouldn't need your own.
If you really want to go down this path without the dyno, you'll need a wideband O2 sensor - the other types won't have enough range to help with what you want. The wideband sensors will be in the $400 range.
Bryan
K
karls59tr
Bronze
Peter I got on the teglerizer site OK but not the first sit you listed. The first site seems to be mostly covered by a blank space? Karl
PeterK
On the first site, you need to click on the needle size. Click .090 on the top line and the program will load.
TR3driver
Great Pumpkin - R.I.P
But note that TR3s use .100" needles, not .090".
Dave Russell
Yoda - R.I.P
As I tried to point out earlier The needle stations/piston lift, do not directly correspond to engine rpm or engine load but to both at the same time ie - air flow only. The needle charts only show a given piston lift. Assuming that 1/2 needle is mid range can result in great errors.
An engine that has relatively large carbs for it's displacement will have much less piston lift for a given condition than the same engine with smaller carbs. If the carbs are large for the engine size, they may never get beyond 1/2 or 3/4 open at full rpm/full power. The first half of the needles calibration range may be all that is actually used.
Don Elliott
The guys you race TRs and who have installed an oxygen sensor put the in a boss that they weld onto the header. One fellow put his 2" down which others said was too close to the engine. They thouught he was reading the flame temperature. Most put them 6" down so they read the exhaust temperature - not the flame temperature. At the end of a long straight, the temperature reads about 1200 deg. F. This temp info is all they use it for.
Deleted member 451
I've often thought about putting two O2 sensers in the lower part of a manifold on the 1 & 4 sections. Thinking this would make setting the mixture a snap to do. Any thoughts?
PeterK
I understand this Dave. Have you seen the program that I linked. Here's a screenshot comparing needles and effect on mixture over rpm. Needles in the comparison are listed in the service manual for TR2 .090" street FV vs. competition GC, as an example.
https://www.mintylamb.co.uk/suneedle/graph.php?n1=FV&n2=GC&n3=&n4=&n5=
So what I suggested was to take the needle chart (as a starting point) to select a couple alternate needles and apply it in this modeling program to graph to effects (and go from there). Maybe the program assumes constant engine load? I didn't write it so I don't know.
martx-5
I've been thinking real hard about doing this myself. I made two bungs up at work just in case I go this route. I'd use a double throw switch so I'd only need one AFR gauge. It would be the best setup. I know I will have at least one O2 sensor on this resto. Might as well take advantage of modern technology. All of the traditional methods of getting fuel mixture correct seem rather quaint and mystical yeilding who knows what results. Chances of getting the mixture more correct by reading Air Fuel Ratios is a whole lot better then lifting pistons, looking at plugs and just generally guessing. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Edit: As far as which O2 sensor to get. I'll dig up the generic Bosch number when I get home, but you want a four wire heated unit. They are more consistent then the one wires, and if you have to locate the O2 sensor far downstream, it will still work. Most O2 sensors have 18mm threads, so that's what size bung you'll need.
TR3driver
I give up; why would they install an O2 sensor to read exhaust temp ? A thermocouple is far more rugged, and cheaper to boot.
For that matter, how does one sort out the temperature signal from the O2 signal, on one wire ?
TR3driver
I'm certainly no expert, but it's my understanding that the wide-band O2 sensors require a periodic 'purge' cycle for operation. Running one disconnected will quickly ruin it.
martx-5
Maybe they're actually using and Exhaust Gas Temerature sender.
martx-5
I'm not going to use a wide-band. A regular generic narrow band sensor will give me enough info for a lot less money.
piman
Hello all,
with regard to piston height, i seem to recall someone using a fuel gauge sender linked to the piston and coupling it to an instrument to read piston height. Slightly crude but it is better than nothing?
Alec
Platinum
Sounds kinda elegant to me, Alec! Ohm meter connected to a sending unit would be fairly accurate, dependent on the spacing of the wires wrapped on the vernier of the sender... Interesting!
Though I s'pose one could be as accurate by just setting a finger athwart the space between piston and block at near TDC and feel the piston hit the full height.
I guess I'll keep the dial indicator. /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
T USB and Auxiliary Power Connections Austin Healey 6
RJS TR4/4A Power (+) Sources Triumph 7
Guido36 Electric Power Steering Austin Healey 2
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
JPSmit Power Pack Restoration & Tools 9
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
R TR2/3/3A Power Steering Triumph 2
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
B Power steering Other British Cars 33
Robert Somma power window installation TVR 3
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
S Power Steering Austin Healey 3
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
S TR2/3/3A power wirer for the heater switch Triumph 16
dougie Paddy Power Austin Healey 3
D Lilly under her own power... Austin Healey 7
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
G The Formula Power Fuel Catalyst!???????? Austin Healey 17
tomshobby TR6 power assist for clutch pedal Triumph 12
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
JPSmit DC Power source thoughts Restoration & Tools 11
F 12Volt Bench Power Supply Austin Healey 4
B Power Brake Servo for a 100 Austin Healey 3
R BJ7 wiring power path Austin Healey 21
F BT7 brales poor stopping power - any advice? Austin Healey 19
KVH TR4/4A Engine Power Triumph 10
drambuie Getting more horse power from a Healey 100 Austin Healey 63
AH67 BJ8 losing power and enguine dies Austin Healey 9
L TR6 No power/not enough power to turn signals, wipers Triumph 8
KVH General TR Power Issue on Acceleration Triumph 13
