CJD
The pinking can be described as knocking, rattling, preigniting. The best description is how it sounds when you tap a steel hammer against the side of your cast iron block...and that IS pretty much what is going on in the combustion chamber when it is happening. It also sounds similar to the old "dieseling" you would hear in the early emmission years when you turned an engine off but it continued to run.
Lugging is when the engine is running too slow in too high of a gear, so your description is correct.
John
John
