I have to agree with you, Lou. I readily concede that brake fade on mountain roads is more likely with front drums; otherwise, I don't know that they're "night and day" different. I've spent an awful lot of time behind the wheel of Heralds and even Mayflowers with all-drum braking systems and have never felt unsafe. In fact, I've had to make one or two serious panic stops and had no problems doing so. Quality parts and regular (as needed) adjustments and maintenance are what you need. Heck, two years ago, a friend of mine wanted me to check out the brakes on his MGA 1500 (Lockheed system, all drums very similar to the TR2). Car stopped, sort of, mostly one front wheel. Three of the four front wheel cylinders were nonfunctional, and the rear cylinders weren't much better. New linings, and new wheel cylinders all around (and a couple new pipes just to be safe), and that car stopped beautifully.Lou Metelko said:I must disagree with your "disc brakes would be hard to pass". I drive my drum brake equipped TR2LD about 4,000 miles per season and as long as you keep the front drums adjusted, they are quite adequate. Still you must remember that even an 80,000# 18 wheeler can stop faster than you. It begs the question "Why buy a TR2 to turn it into a 3A"?
Are discs an improvement? Sure. And vinyl-clad, triple-pane windows might insulate Mount Vernon or Monticello better than the originals, but I personally don't see that as justification for their use on historic properties. But that's me.
In all honesty, I think even us "more seasoned" drivers tend to get used to our modern rides with better brake engineering, arguably better and more durable materials, and all the power assists and warning systems...and then can be surprised when we discover that a bit of real leg muscle is required!
I dunno, Lou, I'm getting to the point where I'm beginning to resemble that remark! :laugh:Lou Metelko said:I resent the term "Senior Member".
