TR3driver
Great Pumpkin - R.I.P
SteveBones said:This will be the first time needing to remove the "drive dog" to rotate 180 degrees. I plan to use a punch to knock out the pin. Not sure if I need to reorder a replacement pin. Since Moss does have both the "drive dog" and the pin, if I can not reuse the original pin, I can order a replacement.
The original pin was a solid "Mills" pin with a slight taper from end to end. If that is still in there, it will only come out one way (without applying excess force anyway). Generally they are reusable.
However, the holes through the shaft & dog are slightly offset (just like the slot in the drive gear), so I am guessing that your pin has already been replaced with a common hollow 'spring' pin. If so, I would replace it as a matter of course. I forget the size offhand, but they are readily available. Most likely, that is what Moss supplies as well.
