TR2/3/3A TR3A Wheel Options
M_Pied_Lourd
Evening All,
I am looking for opinions on the maximum size wheel options I can fit comfortably on a 1960 3A.
For example, can I fit a 7 inch wide rim with 205/65/15's mounted?
What is the maxiumum/minimum offset I can go?
Is it possible to go with a 16 inch rim with lower profile tires if there are issues with wheel rubbing on the control arms?
I am looking at all options available at this stage of the game.
Cheers,
M. Pied Lourd
bluemiata90
I'm not sure of the exact sizes, but last summer I tried to install a set of older Jag. XKE tires on my TR3 and they rubbed when taking turns or large bumps. I can't remember the tire size, but they were stock Jag. size tires, so maybe low profiles would have worked.
tdskip
After thrashing the options around for a bit I ended up with 185/65-15 on stock rims. They work well and look good as well.
Here is the thread ; LINK
alfa33047
Hi M. Lourd, I have tried a couple of different wheels on my TR-3s. The widest wheel you can use is a 6 inch wide, the reason is that anything wider will rub your rear leaf springs. My friend has run 205/60/15 tires but found that they rubed on something up front, so after 10,000 miles went back to 195/60/15 tires. There are several inexpensive Pannasport style 15/7inch wheels on the market that are tempting but they just don't fit. Many years ago when I was racing an RX-3 in SCCA I needed lighter and wider wheels. I couldn't find any thing cheap but I had a set of wheels that had a different bolt pattern. I found a wheel business in Phoenix that redrilled my wheels and installed steel tapered inserts where the lug nuts went. I recently bought a set of EMPI Volkswagen wheels (8 Spoke American Racing lookalikes) and took them over to this company to have them redrilled. They wouldn't drill them for me, their reasoning was that the liability was too great. But they did tell me where to buy the inserts. I want my new project TR-3 to be a little different so I am still searching for a set of wheels. Good luck, I hope that this information helps. Bill C. Mesa, AZ
M_Pied_Lourd
M_Pied_Lourd
Thanks All for the advice.
I am restoring a vintage racing TR3, so I wanted it to maintain that racing look. It came with two sets up rims....one stock set of TR4 or TR250 rims with the studs for the hubcaps and one set of alloys with Yokohama racing slicks installed. I am not crazy about the look of the alloys that came with the car (although they are different.) One guy suggesed that they may have come off of a 70's English Capri. I was looking for something a little different than the minilites or panasports. I may go with the center knock off minilites with spinners although I know that that is a pricey option.
Here is a pic of the alloys that came with the car. If anyone could help identify what they might be off of, that would be appreciated.
Cheers,
M. Pied Lourd
billspohn
TR-3s work well with 5.5" rims, and 6" fit well, but beyond that, if you want to clear everything inboard you are going to have to have all the offset outward and it is going to look like a full size Hotwheels toy.
I routinely ran 5.5" wheels - I liked the TR6 wires on them, and I also ran 14" x 5.5.
When I put on my MGA hill climb wheels that were 7" wide, they of course stuck out of the wheelwell (which makes themn illegal for the street) and also looks stupid. The 7 1/2" slicks certainly worked in the slalom, though!
This is my dead stock (well, I did install a front sway bar, but only because I needed a place to hang the front plate) TR-2 with 72 spoke TR6 wires. Gotta lay them Brooklands screens flat on the track to reduce wind resistance, you know! :jester:
Note the relation of the uotside of the rim to the fender lip - about even.
PeterK
BTDT - lots of previous posts on this subject, if you search.
We run 205/60-15 Yokohama AVS on KN Minator 15x5.5 rims on the 58 3A. Needed a thin 1/8" spacer on the rear to prevent inner tire sidewall from rubbing on the leaf spring in fast corners. The fronts have 1/8" spacers as well and will rub in a hard braking tight corner or backing up fast at full lock. But for normal (even fast) driving, they fit. Can't remember the exact back spacing of my wheels but ISTR it's 3.75". 4" b.s. ain't gonna fit.
-Pete
This is how they look https://mysite.verizon.net/kentech0822/triumph/traaa_sm.jpg
TR3driver
Great Pumpkin - R.I.P
fad64b said:
I have a little rubbing on the front tires when I turn the steering to full lock.
FWIW, you can very likely tweak the steering stops to fix that. I adjusted mine so the 205/55 tires would just barely touch the sway bar.
M_Pied_Lourd
M_Pied_Lourd
Thanks All for the replys. Will let you know what I decide.
Cheers,
M. Pied Lourd
Don Elliott
The little round disk with the hole drilled off center is so easy to make, you could make two of them yourself any size you want.
M_Pied_Lourd
M_Pied_Lourd
Frank,
Thanks for the photos and links to the superlites.
One more question for you....in one of your pictures on photobucket, it looks like you are using hood pins on your three. Is this the case or am I mistaken?
Cheers,
M. Pied Lourd
TR3driver
:iagree: The hole doesn't even have to be off-center, if you get the size right the first time, or grind it down to fit.
vivdownunder
One thing to check before buying wider wheels is that many sidescreen cars had the body mounted offset to the chassis. Typically on such cars the left rear tyre had up to one inch less clearance to the upper wheel arch than the right rear tyre.
Might be worth measuring up the car before making any new purchase.
Wishing you a TRiffic New Year,
Viv.
TR3driver
TS39781LO had that, but it looked like the body itself was asymmetrical. Never did figure out why. It might have been old accident damage, but there weren't any signs of repair in the rear. (The front had previously been crumpled though, and the apron replaced.)
fad64b
Hood pins were installed by the previous owner.
Don Elliott
I have a spacer on the rear spring for the RHS. It was reputed to compensate for the camber in the road where there is a crown. I also heart that it was because a driver is always in the car but the passenger's seat on the RHS in No. America is often vacant. That was rarely my case !
K For Sale TR3A Steering wheel Triumph Classifieds 4
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Lukens TR2/3/3A Aligning steering wheel on TR3A Triumph 3
Simmo TR2/3/3A Mota Lita Steering wheel on TR3A. Help! Please. Triumph 4
NutmegCT TR2/3/3A TR3A wheel bearing? Triumph 7
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
PatGalvin TR2/3/3A Steering Wheel Diameter with R&P Steering, TR3A Triumph 9
Tinkerman TR2/3/3A Interior Vinyl on the Wheel Arches TR3A Triumph 9
K TR4/4A TR3A wheel hubs and TR4A wheel hubs? Triumph 2
K TR2/3/3A TR3A wire wheel hub splines question. Triumph 9
Dan_Pasta TR2/3/3A Need TR3A wire wheel opinions Triumph 7
Got_All_4 TR2/3/3A TR3A wheel paint Triumph 16
Don Elliott TR2/3/3A Tightening Front Wheel Brgs - TR3A Triumph 10
M TR2/3/3A TR3A steering wheel splines Triumph 1
B TR2/3/3A TR3A front wheel bearing question Triumph 5
K TR3A wheel hub bolt upgrade.... Racing 5
K TR2/3/3A TR3A stock wheel offset and wheel size? Triumph 2
T TR2/3/3A TR3A wheel alignment Triumph 12
NutmegCT TR2/3/3A TR3A spare wheel compartment picture Triumph 24
C TR2/3/3A I want to change my Tr3A steering wheel... Triumph 6
J TR2/3/3A tr3a wire wheel help Triumph 5
F TR2/3/3A TR3A Steering Wheel Cover Triumph 1
txtr3 TR2/3/3A TR3A front wheel bearings and seals Triumph 4
S TR2/3/3A TR3A steering wheel Triumph 32
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
