deadair
I recently got a vacuum bleeder and tried it on my TR3A last weekend to bleed the brakes. I noticed that the bleeder was not extracting sufficient fluid from the system. It was as if there was some blockage at the master cylinder. Depressing the brake peddle resulted in the expected amount of fluid.
So, I'm thinking that maybe the girling master cylinder might be designed so that you can't extract fluid at a brake cylinder or caliper from the reservoir with the peddle in the up (none-depressed) position. Is this true? If so, is the solution to use a piece of wood, or something, to keep the peddle depressed?
Hi Guest!
