TR4nut
Has anyone seen a factory writeup or tech bulletin on when to use shims for the starter motor? I'm hooking up a later style starter to my 3A, now with a bolt on ring gear. Have a few shims sitting around but I've not seen anything as far as pre-measuring and using shims to fit. Is it just something to try if you have interference issues when you try to start?
