TR2/3/3A TR3a Spedo question
ekamm
When I first started working on my non O.D. TR3a I noticed that the spedo cable is disconnected. I disconnected the cable at the spedo to see if the cable would turn. I was hard but I could just turn it by hand. I decided to remove it to clean it out and did every thing seems well so I replaced it an was able to turn it and move the needle. Then I looked at the tranny and where do I put the cable end? I'm not sure but after I look at the workshop manual I'm pretty sure, but the bearing and gear appear to be missing and a bolt put in their place. No wonder at $42 and $20 each I assume that's why it was disconnected. Can someone show me a pic to let me know for sure where it goes?
MGTF1250Dave
I don't have a photo, but her is a diagram. The speedo drive is on the left side of the gear box just behind wear the tail shaft housing bolts to the gear case and just forward of the rear mounting bracket. It is a brass color and is angled slightly downward. It is labeled 74 in the diagram.
TR3driver
Great Pumpkin - R.I.P
Note that there is also a threaded adapter (item 21 in this diagram) that doesn't appear to be available new anymore.
But if you can wait until after TRfest, I've probably got one I could part with, somewhere. Or you might be able to talk Bill C. into pulling one from his bone pile.
ekamm
ekamm
my problem is where is the hole in the tranny. It was late and from the diagrams that I have seen it appears to be aft of where I was looking. I'll take some time this afternoon and look again. All I saw was the plugs on the side of the gearbox and appears to be behind the flange there.
TR3driver
Yes, it's on the tail housing, just behind the flange. Here's a shot from Nelson, your gearbox won't look exactly the same, but the speedo drive is in the same place.
ekamm
ekamm
Awesome thanks I' ll let you know what I find when I'm home later.
ekamm
ekamm
Well here's what is in place of the connection for the spedo cable. Looks like a blanking plug. My dad used a couple of "mechanics" over the years and evidently on of the blocked it off for some reason. Could a bad bearing have caused a problem with the gear?
https://
[/img]
TR3driver
Almost looks like that is a different tailhousing. Could this gearbox have come from some other car in the past?
There could have been a problem with the bearing I guess, but I've never seen or heard of someone having trouble like that. The usual way to break the gear is to forget to pull it out before trying to remove the tailhousing for a rebuild.
ekamm
ekamm
I don't know of any changes but I guess it is possible. After 1986 I wasn't around the car much. My dad is getting old, but I'll see what info I could get out of him and see if the mechanic is still around.
ekamm
ekamm
Is the hole on the other side for RH drive cars?
Moseso
No. There are, however, RHD & LHD cables for both speedo & tach. That's where they accommodated the difference.
ekamm TR2/3/3A TR3a spedo drive Triumph 19
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Hamish Racing TR2/3/3A TR3a video Triumph 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
angelfj1 TR2/3/3A TR3A Stone Guards Triumph 3
