Bremer
I have a problem where I would appreciate the forum members' input.
I was doing a tune-up on my 59 TR3A (with an early TR4 engine) and noticed the following:
- When pulling the leads off the #1 or #2 plugs at idle, the engine sound or speed does not change.
- When pulling the leads off the #3 or #4 plugs at idle, the engine stumbles and almost dies.
This led me to believe that the engine runs on two cylinders only (at least at idle). The first question is whether this conclusion is actually correct.
Things I have done to diagnose the problem:
- The plug ends of the leads do spark when held against ground.
- The plug gap was a little wide, I reduced it to 0.025''. No difference.
- Swapped leads and plugs between cylinders. The problem does not follow either.
- Checked compression: All between 100 and 108 psi. (I believe my gauge reads low since two other engines have been checked with similarly low readings)
- Ran the engine with the valve cover off: All valves move approximately the same amount (eliminates wiped-out camshaft).
- Measured lead resistance: Appears to be around 10 kilo ohm for all of them. This compares with about 300 ohm for new ones that I had ordered (not installed yet because they came without terminals that fit into the distributor :m).
- Loosened throttle shaft connection between carbs and increased front carb idle throttle setting, thinking the carb might starve cylinders 1 and 2. This moved the problem to cylinders 2 and 3, i.e. when pulling those leads the engine did not stumble.
Other observations/information:
- There is a point just slightly above idle speed where the engine rocks so much in its mounts that it's impossible to adjust throttle settings with a screwdriver.
- It had failed the emissions test (mandatory here for everything that drives on BC's roads) with high HC and CO at idle as well high CO during the driving test. It passed on HC and NOx in the driving test, where NOx was extremely low.
Sorry for the long message, just trying to provide all info that might be relevant.
Comments welcome!
Thanks very much.
Comments welcome!
